96 r ecu
Old Oct 7, 2009 | 02:58 PM
s_moneh's Avatar
Default 96 r ecu
if i were to be able to get my hands on a 96 R ECU and wanted to put that ECU in my 96 turbo, is that possible? wat can i expect to change? and would anything get affected by it? would i have to replace any certain amount of parts?
Old Oct 7, 2009 | 03:14 PM
gilber33's Avatar
No, it's a direct swap. You technically get a 40 hp gain,which equals to about 1-2 more psi boost for a second or two. You would get more gains with a boost gauge and MBC, but more efficient gains with the ECU.
Old Oct 7, 2009 | 03:25 PM
s_moneh's Avatar
couldnt i just do all 3? ECU, MBC, and boost guage?
aswell wat r great MBC's but nothing to intensely expensive
Old Oct 7, 2009 | 04:03 PM
boxpin's Avatar
I have a 95 T-5R ECU for Sale
Old Oct 7, 2009 | 04:05 PM
s_moneh's Avatar
would that work fine on a 96 turbo? and how much?
Old Oct 7, 2009 | 04:57 PM
gilber33's Avatar
It would work for a 96 but you will get a CEL for the EGR. Just do a google search for MBC. You could do all three, but it would be kind of pointless. The instead of 9-10 PSI on the stock ECU, the R ECU gives you 11-12 PSI, so there's really no reason in spending the money on a MBC for one more psi.
Old Oct 7, 2009 | 06:19 PM
s_moneh's Avatar
CEL/ EGR?????
and oooo well if i can get both parts cheap then i'd be pretty happy
Old Oct 7, 2009 | 06:24 PM
gilber33's Avatar
You'll get a check engine light for the EGR because his ECU is from a 95 T5-R which had the EGR and your car is a 96 which did not have the EGR. So the ecu will work, but it will be looking for an EGR and not find one, hence the CEL. I would either get the ECU or the MBC, doesn't make sense to get them both. IMO the ecu would be a better buy because you'll be getting a little added HP and boost the proper way.
Old Oct 7, 2009 | 06:29 PM
s_moneh's Avatar
makes sense, wat does a used R ecu go for no adays, even if i hit some junkyards to find the ecu?
Old Oct 7, 2009 | 06:49 PM
gilber33's Avatar
Good luck at jy. One, because they're aren't that many R's to begin with, and two, they're a hot item. Usually they go anywhere from 100-150.
Old Oct 7, 2009 | 07:09 PM
Legendsecko87's Avatar
Or.
Spend a good 700 on a IPD one. I can grab a used IPD one for 450 locally. I know a guy selling his.
Old Oct 7, 2009 | 07:31 PM
gilber33's Avatar
If you go that route, I would highly recommend a full stage zero and exhaust first.
Old Oct 8, 2009 | 12:02 AM
boxpin's Avatar
S_moneh,
Do your homework and shoot me an offer.
Its a good ECU from a running T-5R.
Old Oct 12, 2009 | 01:03 PM
s_moneh's Avatar
alrity checked inventory at some local junkyards and it just so happens thers 3 96 R's at the scrapper( i know sad!) soooo now that i have found some candidates, how do i know which big block in the box is the ECU so i can go ahead and take one and slap it into mine?
Old Oct 12, 2009 | 01:29 PM
gilber33's Avatar
Pretty sure it's the ones that say 7.2 on them. I think. Where are you located anyways?
Old Oct 12, 2009 | 01:36 PM
s_moneh's Avatar
not far from toronto, its in a toronto scrap yard, canada
Old Oct 12, 2009 | 01:56 PM
  #17
Bosch = ECU
Asian Warner = Tranny module.
Old Oct 12, 2009 | 02:07 PM
  #18
gilber33's Avatar
I want a pick n pull so bad, I would go there every weekend to buy stuff.
Old Oct 12, 2009 | 02:12 PM
  #19
s_moneh's Avatar
Originally Posted by tech
Bosch = ECU
always? perfect, thanks so much
Old Oct 12, 2009 | 02:14 PM
  #20
Unless it is a stick then it will only have the Bosch one.
