97 Volvo 850 Glt p1505 and p1507
Old Aug 3, 2014 | 04:05 PM
Dfisher85's Avatar
Default 97 Volvo 850 Glt p1505 and p1507
I have a 97 850 glt, I just replaced the PCV system and cleaned the IAC while I was doing it. I had some codes before replacing the PCV and now those are gone. The new codes I have aren't the same as the old codes.
I am getting a P1505 and P1507 with a slightly rough idle. Should I take the IAC off again and try to clean it better?
Old Apr 28, 2022 | 01:46 AM
Oley's Avatar
Default P1507 & p1505
wondering if you ever figured out a solution/reason for you problem. Having similar symptoms.
Old Apr 28, 2022 | 07:45 AM
tonyfr's Avatar
Check all of the vacuum lines for leaks
Old Apr 28, 2022 | 01:15 PM
+1 on looking for vacuum leaks and intake air leaks. Keep in mind, the PCV system uses the vacuum to capture/burn the blowby emissions so you may have something going on with those hoses or with the oil separator. Probably requires a smoke test on both the vacuum lines as well as the intake air path.
See this thread: https://www.matthewsvolvosite.com/fo...ic.php?t=82766
Old Apr 29, 2022 | 02:19 AM
Oley's Avatar
Turned out to be the MAF sensor. Popped a new one in and it's back to normal.
Thomas Lindberg
Jun 27, 2016 03:39 PM
volvo97glt
May 24, 2013 08:55 PM
ScottyJ
Jul 21, 2012 02:14 PM
squiz
Sep 1, 2010 09:05 AM
HRH
Sep 7, 2009 08:24 PM
