AC high side charging port location?
Old Nov 22, 2005 | 02:11 AM
850forum's Avatar
Default AC high side charging port location?
I can find the low side charging port, on the passenger side front low down dangerously close to the spinning flywheel.
But where's the high side connection, on a 1995 850 Turbo Wagon?
Old Sep 8, 2012 | 02:17 AM
You are only suppose to charge the low side. There is no HIGH SIDE charging port. Yes, it may shave a few hairs off your fingers. LOL
Old Sep 8, 2012 | 07:44 AM
Brick850's Avatar
+1 for RSPI......this is the first car I've come across with only the one port.
Old Sep 8, 2012 | 03:14 PM
Yup, there is no high side port on my 850. I had someone challenge me on it and I went over that high side end to end as every other vehicle with AC from back in the fifties up to the present has always had both. The 850 does not.
If you managed to hook up to the high side to try and charge your system the only thing you'd do is have the can blow up in your hand. The freon cans aren't strong enough to handle the higher pressure.
Attached Thumbnails  AC high side charging port location?-heat-ac-actic-freeze-r134.jpg
Old Jun 30, 2021 | 04:57 AM
bobajob's Avatar
hi
does the 2000 mk1 v70 have a high side charging ac port --my local garage cant find one
apeman
Jul 2, 2023 02:28 PM
stuttgart
Mar 21, 2013 06:22 PM
TONY12340
May 19, 2011 11:45 PM
Patdon10
Jul 24, 2007 08:14 PM
tennengr
Apr 13, 2006 05:04 PM
