Acceleration Sensor
Old Feb 9, 2008 | 05:19 PM
Tengu's Avatar
Default Acceleration Sensor
Anyone know what the Longitudinal Acceleration Sensor does? I keep getting an error code associated with it (p1308) and the light goes out when it is unconnected. I was wondering what it was for and if really needs to be replaced immediately. Normally I would just replace it but the only place I can find the part at prices it at over $300 and the part isn't that big.
Old Feb 9, 2008 | 06:11 PM
Default RE: Acceleration Sensor
If you are talking about the one mounted to the front of the subframe try to replace it ASAP.
I say that because it completes a circuit.
There is other parts connected in the circuit.
The A/C high pressure switch,Fuel tank pressure sensor and Map sensor are all in the same circuit and if one goes bad it affects all of them.
Did you check the wiring really good?
Sometimes when you bump the parking stops the wires can get knocked down and cut.
volvorecycle
Jul 22, 2015 07:44 PM
chachouu
Jun 8, 2012 04:35 AM
chachouu
Jun 6, 2011 08:53 PM
rcsoundn1
Apr 5, 2009 01:19 PM
rcsoundn1
Mar 12, 2009 10:01 PM
