air temperature sensor and a/c lights blinking
Old Dec 26, 2007 | 11:34 AM
deathbots's Avatar
Default air temperature sensor and a/c lights blinking
Hi, all.
I made a post a while ago
https://volvoforums.com/m_66493/tm.htm
In that post I described how my a/c lights were blinking when I started the car, and the problem was likely the air temperature sensor (not the one related to the dashboard temperature readout). I had a picture of this sensor in the haynes manual, and JPN was kind enough to lend assitance. Despite his best efforts, it remained elusive. I took it to the local volvo dealer. They charged me some money for their trouble, but they could not find the sensor. Their conclusion was that it was missing. I wish I knew why someone would have removed the sensor and never reconnected it.
Sooooo
1) what is this sensor good for?
2) if it's good for something important, does anyone have a part number?
3) Pretty weird, huh?
Old Dec 27, 2007 | 08:38 AM
Psaboic's Avatar
Default RE: air temperature sensor and a/c lights blinking
Definitely a bit on the strange side that is for sure
Old Dec 27, 2007 | 09:08 AM
JPN's Avatar
JPN
Hello again,
And here's another attempt:
There are a total of 5 temp sensors for the AC input. 2 on each side behind the handles, 2 on the duct, and the last one in the engine compartment. See attached pic.
The sensors provide temp input to the ECU, and then the ECU decides what temp is most suitable for the given condition. It may turn on/off the AC compressor, etc...
If the AC works fine after the blinking stops, I would leave it as it is. If, however, it fails to function, then you may want to retrieve the code again to see if the same code comes back. The code tells you which sensor is faulty.
I am not sure if the sensor was actually missing or if it failed to function. See if you can find them on your own. It is hard to imagine someone would have removed a temp sensor, unless by accident.
I hope this helps this time.
JPN
[IMG]local://upfiles/6892/38446C0017974B11A08E5F71CB5A9BB6.jpg[/IMG]
mezwestrope
Dec 18, 2013 02:22 PM
andysvolvo
Sep 10, 2012 07:52 AM
rnlmorris
Aug 29, 2010 07:46 PM
Maruccio
Jun 9, 2008 05:48 PM
PE**2
Mar 14, 2008 10:30 AM
