All warning lights on?????
Old Jun 17, 2009 | 10:15 PM
gabyman97596's Avatar
Default All warning lights on?????
OK i recently repair the car from a crash; used hood, bumber, and one headlight. now im having a problem that when i turn off the car and remove the key from the ignition all of the warning lights stay on as if the key is on the starting position but the key is not on the ignition sometome happens some times not and now os more often any thoughts ideas???????
Old Jun 17, 2009 | 10:24 PM
850tony's Avatar
do the head lights work?
Old Jun 18, 2009 | 10:00 AM
bestharry's Avatar
electrical portion of the switch would be the primary suspect. Next time it happents, just remove the steering column cover and disconnect the connector to ignition switch and see if that helps. If it does, then all you need is the electrical portion of ignition switch (common problem).
Old Jun 18, 2009 | 02:17 PM
850tony's Avatar
i was thinking that or maybe the box in the front passanger side of the engine bay got f'ed up in the crash... just a thought.
Old Jun 18, 2009 | 06:21 PM
yes the headlights work when i took the key out of the ignition the turn off but the ones on the dash board stay on even the light from the economy or sport mode.. i will try disconeecting the cable for the ignition and see if that is the problem.. i don't think its the box on the passenger side of the engiine is intact the only thing that i change was the bumper, hood, the big bumper that grab the headlights..
Old Jun 18, 2009 | 06:59 PM
850tony's Avatar
ok in that case i vote ignition also.
unless in the crash your broke a grounding connector or something crazy like that...
Old Jun 18, 2009 | 07:18 PM
i doubted cause when i was putting all the parts didnt see any broken cables, cause it didnt touch the headlight it broke it lens but the headlight assembly is intact but will check tommorow on the ignition thanks!!!!!!
dmg4
Dec 22, 2021 11:03 PM
glixons
Jan 4, 2015 06:15 PM
neco223
Jul 20, 2014 07:29 PM
labelsdc
Apr 15, 2011 08:57 AM
