Another 850 cranks but no spark problem
I have a 1994 850 T-5. It cranks but will not start.
I also have a second 1994 850 T-5. It runs fine and I am using it to troubleshoot the other one.
Here is what I have done so far:
Swapped ECU's.
Swapped cam and crank sensors.
Swapped Coils.
Replaced the fuel pump and relay.
I get no spark from the coil at all. The coil is getting power. The fuel pump is working great and I get plenty of fuel pressure. I have an OBD II reader. It says code p0120. Is the TPS enough to cause no spark at all? I have heard that it could be caused by a problem with the alarm system. I have no remotes and simply use the key to lock and unlock it. I bought this car non-running. The previous owner said that the dealership had it running with a new computer. (most likely a lie)
Any help would be greatly appreciated. I am getting to my wit's end.
Swapped ECU's.
Swapped Coils.
it is your cam position sensor and make sure u set the wires away from the rpm sensor causes communication problems or either check your injection relay located by the coolant fan. 94 has three modules ignition fuel and trans. depends if u have a regina system
WOOOOOOOOOOOOOOOOOOOOOHOOOOOOOOOOOOOOOOOOOOO!!!!!! !!!!!!!!!!!!!!!!!!!
It's alive!!!! It was a bad transmission computer. It fired right up. Lots of lifter tick and some rough idling, but nothing some Seafoam, plugs, wires, cap and fresh oil won't cure.
A HUUUGE thanks to everyone who contributed! You guys rule. This is why I keep getting Volvos. I will post up pics of the 850's real soon. Not too bad for $500 each!
nightmarevolvo
02-04-2023 06:20 PM
