Another 850R no start
I have a 96 850R. That just died. Has gas at the rail and good spark. IAC is good. Will crank but not start any ideas?? Have to remove battery so no stored codes |
removing the battery shouldn't clear the codes. U Check the fuel injector relay (up under the radiator cowling)?
Oh. Well i dont have any codes then . Yes. The relay was fine i swapped it out and checked connections. The plug tips are wet with fuel |
I actually had the plugs laying across the head while testing for spark and got a nice little flame out the plug hole while crankIng so i guess fuel pressure is good. Haha |
Unplug the MAF? I mean if you're getting fuel into the cylinder, and the spark plugs set it on fire.... It's not dead, it's merely a little confused.
Ive swapped MAFS and unplugged. Nothing.. im puzzled?? |
Maybe starter not quite fast enough altough it spins and sounds ok. I have 3 other 850s |
