Another 850R no start
Old Nov 18, 2018 | 12:22 PM
860ARE's Avatar
Default Another 850R no start
I have a 96 850R. That just died. Has gas at the rail and good spark. IAC is good. Will crank but not start any ideas?? Have to remove battery so no stored codes
Old Nov 18, 2018 | 08:02 PM
removing the battery shouldn't clear the codes. U Check the fuel injector relay (up under the radiator cowling)?
Old Nov 19, 2018 | 04:57 AM
860ARE's Avatar
Oh. Well i dont have any codes then . Yes. The relay was fine i swapped it out and checked connections. The plug tips are wet with fuel
Old Nov 19, 2018 | 05:24 AM
860ARE's Avatar
I actually had the plugs laying across the head while testing for spark and got a nice little flame out the plug hole while crankIng so i guess fuel pressure is good. Haha
Old Nov 20, 2018 | 12:39 PM
firebirdparts's Avatar
Unplug the MAF? I mean if you're getting fuel into the cylinder, and the spark plugs set it on fire.... It's not dead, it's merely a little confused.
Old Nov 20, 2018 | 01:11 PM
860ARE's Avatar
Ive swapped MAFS and unplugged. Nothing.. im puzzled??
Old Nov 20, 2018 | 01:14 PM
860ARE's Avatar
Maybe starter not quite fast enough altough it spins and sounds ok. I have 3 other 850s
Richiebuonanotte
Oct 15, 2018 12:15 PM
860ARE
May 21, 2018 08:38 AM
anty
May 19, 2018 03:50 PM
860ARE
North East
May 4, 2018 09:18 PM
rjonny13
Jun 8, 2009 05:35 AM
