Another dash lights thread
Old Apr 27, 2021 | 07:49 PM
GreenMountainBricks's Avatar
Default Another dash lights thread
Ok, so I picked up a 94’ 850 last week. The rheostat works, at least, it dims the clock and emergency light switch. I can’t find a wiring diagram for the dash lights that isn’t a broken link from a 10 year old post. I did try jumping terminals 1&4 and nothing happened except rheostat at 100%, and I’ve seen it dim the other bulbs so it works. I checked the fuses and tried swapping them. No changes.
Am I missing something? Do I have to pull the cluster and check if voltage is getting to a connector in the back? I can check the cluster for continuity from there if parts are accessible.
thanks in advance
Old Apr 27, 2021 | 11:56 PM
tonyfr's Avatar
Try this wiring diagram.
File Type: pdf
Old Apr 28, 2021 | 10:24 AM
thank you, this is what I was looking for, guess I’m heading into the dash this morning with my
meter.
Old Apr 28, 2021 | 04:24 PM
tonyfr's Avatar
Let me know if you need anything else (diagram wise).
Old Apr 28, 2021 | 06:21 PM
meter.
so I pulled the dash, lost half the screws inside the lower dash trim that’s another issue), and found the previous owner tried(unsuccessfully) to add led dash lights, at least the 4 for
illumination in the cluster. I can’t get continuity across the 4 bulb holder terminals. I can with every other light holder. I can’t tell if the bulb holders are original and retrofitted with led’s that just aren’t making contact. I did confirm voltage makes it to the connector itself.
Led in bulb holder
Back of cluster
Old Apr 28, 2021 | 10:44 PM
tonyfr's Avatar
Those look like original bulb holders. I would just remove the LED's and go with regular bulbs. The previous owner of my 855R changed the dash bulbs to blue and a few of them blink on and off (mostly off). I have to pull my dash to replace all of the bulbs.
Old Apr 29, 2021 | 05:10 AM
ok, thanks for confirming, I’ve read about people having to bend terminals to get contact. Normal lights it is!
Jared98112
Feb 12, 2014 06:16 PM
mcnaught82
Interior
Jan 23, 2013 12:01 AM
harebearva
Oct 18, 2008 11:09 PM
MyDaughters740
Apr 22, 2008 08:10 PM
Alexander
Jun 28, 2005 10:33 PM
