Dash lights...
Old Feb 10, 2014 | 10:58 PM
Jared98112's Avatar
Default Dash lights...
I need to replace one of my "idiot" lights as well as the lights for the LCD screen at the bottom of the instrument cluster (shows temp, miles to zero, etc.) and hope it's not as hard as it looks. Robert DIY shows taking the entire dash pad off but I'd rather not if I can avoid it. Any links or advice would be fantastic. I'm hoping for a quick r&r of the bulbs. Oh and if y'all know what kind of bulbs are in there that would be awesome. I assume they are like a million dollars and have to come from the dealer...
Old Feb 11, 2014 | 01:46 AM
Brick850's Avatar
There is no shortcut to removing the cluster......the dash top has to come off.
Don't try and undo just one side then bend the dash top back, you will deform it and it wont sit right ever again.
In my cluster the idiot lights are a Toshiba V2 globe (google it) however the LCD screen globes differ from what options there are. Plain cluster had one globe, multi function trip computer had 2 globes.
Old Feb 11, 2014 | 04:22 AM
scutyde's Avatar
Replace the 4 big bulbs which illuminate the whole cluster . The bulbs are rated 3watts get these and beware the 5watt one s are more common but the plastics inside will not be thrilled to get more heat.
If the car has the BC there are 2 small bulbs which are Volvo specific but not very expensive (2$ per pcs), otherwise there is just one of these bulbs fitted.
As brick stated there is no "shortcut" for replacing the bulbs you have to take the cluster out.
Cristian
Old Feb 11, 2014 | 11:07 AM
Phil 850's Avatar
As everyone else said, there is no short cut. My advice is really take your time putting it all back together. I missed something when I did this and have had a very annoying squeak from the passenger side of the dash ever since and will have to take it all apart again to fix.
Old Feb 12, 2014 | 02:08 AM
Jared98112's Avatar
Awesome. thanks folks. One more thing, is there any issue with removing the bulb for the "service" light? I heard that some of the idiot lights will trigger others if the bulb is burned out so I don't want to trade a minute (at startup) of having the service light on for an eternity of check engine. I found a cheap kit from eeuroparts.com that has all six bulbs for the cluster, but what bulbs are the "idiot lights? Thanks again!
Old Feb 12, 2014 | 03:03 AM
Brick850's Avatar
By idiot lights I am assuming the lights like the service and check engine lights.
Toshiba V2. Google it.
Old Feb 12, 2014 | 06:59 AM
scutyde's Avatar
There is no issue with removing the SRI (service reminder lamp) however it has it's purpose to remind you that you need to change (at least) the engine oil.
Old Feb 12, 2014 | 06:16 PM
Yes, remove the idiot light since you do NOT have a reset tool.
I have bulbs if you need them. They are cheap. My cluster video should show the bulbs, not the details.
Ratphink120
Mar 11, 2022 10:41 AM
mikwik
Oct 22, 2011 05:42 PM
zloetakoe
Aug 27, 2011 02:06 PM
850GLE
Sep 22, 2009 10:28 AM
tr_car_nut
Jan 19, 2008 09:37 AM
