any fuses/fusepanels in trunk of wagons?
Old Mar 1, 2009 | 08:20 PM
chef's Avatar
Default any fuses/fusepanels in trunk of wagons?
Hi guys two quick questions:
1. Are there are any fuses or fusepanels in the trunk of wagons?
2. where would i check to see if the antenna on my wagon is grounded properly?
thanks
fabs
Old Mar 1, 2009 | 09:27 PM
No fuses in the trunk.
Under the panel on the left side rear side window.
Old Mar 1, 2009 | 10:14 PM
chef's Avatar
Hey Tech, what's up? so is it the panell right underneith the the antenna wires on the driver-rear quarter panel window? how and where do i remove the panel? what is there...fuses? relays?
thanks
fabs
Old Mar 1, 2009 | 10:36 PM
The panel is a pain to get out. Start at the back and work foward.
There is connections under there you can check.
I am doing pretty good how about you?
Old Mar 1, 2009 | 10:39 PM
chef's Avatar
Hey, we're doing well thanks, busy as usual..still cold up here...
Is there anything behind this panel that might effect either the radio antenna or the rear wiper? thanks
fabs
Old Mar 1, 2009 | 10:41 PM
Maybe just the antenna if the wires fell off or are making a bad connection. I believe it is like a 9 volt battery wire connection to the glass.
I don't think it will affect the wiper at all.
Old Mar 1, 2009 | 10:48 PM
chef's Avatar
Hey, ya i remember that the guys unplugged the contact on the glass for the antenna..yes it is like a 9v battery. They had a bit of a hard time connecting it again. The thing is that, i don't think that they took off that pannel when they tinted the glass. i can take a look to see if there is something.thanks
fabs
Ryan911t
Apr 13, 2014 10:19 PM
Mie518
Apr 30, 2011 02:49 PM
rspi
Feb 10, 2011 09:48 PM
ryans89notch
Sep 15, 2010 08:59 PM
Vincef
Mar 18, 2009 08:42 PM
