Anyone think this is a good deal?
Old Oct 4, 2011 | 02:44 PM
RecklessWOT's Avatar
Default Anyone think this is a good deal?
Hey guys,
Volvo Control Arms Suspension Kit Shocks Struts Mounts (850 V70 S70) - OEM 850KIT10FR | FCPEuro.com
I'm thinking of ordering this up for my 850, but I wanted a few opinions.
It looks like the most expensive kit they offer, but even so it's wayyy cheaper than the dealership... I also want the best kit I can get without completely changing the way my suspension works (although I wouldn't even say it "works" as of now anyways lol). Do you think I should go ahead with it? Anyone have experience with these parts in this kit, quality-wise?
I've bought parts through FCP on their old website before for my 760 and they really impressed me. I was recently told I should check out their new FCPEuro.com site, I guess they've got even better deals there. (I really like it too, the fitment info is much better than the old site, a lot more cut and dry.)
Also do you think there's anything else I should replace at the same time while I'm down there? The kit seems pretty complete, they claim it's EVERYTHING you need, but I'm not sure if there's anything else that's a good idea to add in as well on my own.
I'm doing my axles at the same time, they need it pretty bad too.
Thanks in advance guys!
Old Oct 4, 2011 | 03:40 PM
MattyXXL's Avatar
I ordered this kit a little over 3 years ago... Not a problem since.. My advise, call there and talk to mike and make sure those are the bilstien shocks and struts
Old Oct 4, 2011 | 10:31 PM
gdog's Avatar
Bilsteins? Thought it says they're Sachs? Which are fine; though the Bilstein TCs (or HDs if you're into that..) would be better IMO.
I would also call them and make sure:
  1. the LCAs are indeed OEM, not ScanTech or other aftermkt.
  2. the front upper strut bearings are OEM; not aftermkt. Lots of problems w/aftmkt ones rubbing when turning.
  3. the front upper spring caps are OEM or better yet OEM XC (or suggest the HD ones IPD sells)
  4. oh yeah, the tie rods ends too should be OEM
I would be concerned the ad says "OEM quality" and doesn't say "OEM". Call to verify.
For your suspension parts if you go w/OEM or better, it will last you another 100K+ mls. If you go with something less you'll get through the year warranty period, but not much farther before you're doing it all over again..
058ovlov
Mar 3, 2012 01:36 PM
shinesinpines
Mar 8, 2007 07:15 PM
Squid56
Aug 25, 2005 09:16 PM
ronronaldo
Aug 27, 2004 06:29 PM
