Autocross and Time Attack
I'm trying to narrow down a list of future modifications to improve the handling of my car (96' 854 with the N/a 2.4L and M56) for Autocross and eventually Time attack racing (amateur level) without ruining drive-ability.
So far I've found; BC Racing Coil-overs ($990) Not much more expensive than good shocks/struts and IPD coils and more adjustability IPD Sway bars Subframe bushing inserts (and new bushings in general) Short shifter from Viva Performance Up-fitting to 17" OEM wheels (probably Thor, Otrera, or Tethys) New 200-300 TW Performance Summer Tires (Stays warm enough year round to not need to worry) 302mm Front Rotor Upgrade Possibly mild weight reduction Battery Relocation to rear (for a 40lb battery changes weight distribution from 58% front / 42% rear to 56.5% front / 43.5% rear) Eventually a harness bar and harness. Front splitter and a small rear wing (mostly for looks) Any other Ideas to add to the list? |
Any and all of those modification will put your car out of stock class.
Originally Posted by tryingbe
(Post 458826)
| All times are GMT -5. The time now is 10:34 AM. |
