bad gas mileage
Old Jul 8, 2007 | 06:56 PM
glt93's Avatar
Default bad gas mileage
Two questions can a bad pcv system affect my mileage and can a bad or clogged fuel pump also affect my mileage
Old Jul 8, 2007 | 08:14 PM
JPN's Avatar
JPN
Default RE: bad gas mileage
Hi,
Two answers:
1) Yes, a poor PCV system can definitely affect gas mileage and will eventually allow internal pressure in thecrankcase to rise, which will give you a nightmare (oil leaks everywhere, blown oil seals, etc...). If it hasn't been serviced in the last 3-4 years or so, I would service it now. If you can service it yourself, great but if not, you could perhaps buy OEM parts on-line and find a shop that accepts parts from customers. Expect the labour to be a bit higher, as shops make profit by selling you parts as well. Insist on OEM parts whenever servicing your Volvo (unless you plan to get rid of it within a year or two), as most cars are sensitive to the quality of parts, and lately there are many inferior aftermarket parts floating around. Many members, including myself, use FCP Groton of Connecticut:
http://www.fcpgroton.com/volvo.htm#850
2) This one I am not 100% sure. But if the fuel pump is in poor condition, it would give you starting/drivability problems. Fuel pump itself wouldn't get clogged, but there is a fuel strainer at the inlet of the pump and it is possible that the strainer can get clogged. Also, have the fuel filter replaced at every 30,000 miles or so. Owner's manual calls for filter replacement at every 60,000 miles, but I personally feel it's way too stretched. I personally replace mine at every 30,000 miles or 3 years.
I hope I've answered your question. If I've missed something, other members can correct me.
JPN
bigmreds64
Oct 27, 2010 09:46 AM
cm123
Mar 26, 2009 10:37 PM
Earwig225
Dec 12, 2008 06:21 PM
samadkins29
Aug 18, 2007 01:57 PM
ko_kidd
Nov 5, 2006 05:52 PM
