Battery Questions
Old Oct 30, 2008 | 06:15 PM
raybun's Avatar
Default Battery Questions
The battery died in my 96 850, probably from old age. After the new battery was in place I measured the battery drain with the ignition and all lights and accessories off. I measured a draw of 11Ma. I this normal? I also had a 9v battery plugged into the cig lighter socket to maintane settings. I still lost the settings (time, radio etc.) Is there a trick to using one of these settings savers?
Thanks
Ray
Old Oct 31, 2008 | 07:19 AM
Default RE: Battery Questions
.025 amps pull is the max allowed.
If you do it right you will not loose your settings in the car.
Most of those aftermarket things don't work on the volvo's.
Old Oct 31, 2008 | 08:59 AM
Psaboic's Avatar
I have tried a couple of those things on several different venicles and I lost my settings every time!
Jeffers
Nov 21, 2012 06:50 PM
Phil 850
Jul 25, 2012 10:01 PM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
ks*annie
Sep 13, 2006 08:17 PM
