Belt Problems
Old Jan 9, 2009 | 03:52 PM
spartan1251's Avatar
Default Belt Problems
What is the belt that is on the left side of the engine? If looking down on it from above.
It looks like it is next to the timing belt.
When I start the car, that is squeeking a little bit.
Its a non turbo engine.
Old Jan 9, 2009 | 03:53 PM
Default RE: Belt Problems
That is the serpentine belt.
Old Jan 10, 2009 | 01:03 AM
JPN's Avatar
JPN
And the belt drives power steering pump, alternator, A/C compressor & secondary air pump if so equipped.
If squealing, the tensioner may need lubrication/replacement (unless the belt is contaminated with coolant/oil or being glazed). I would also replace the belt with OEM Continental Tech. There are 2 different length belt and the longer version is recommended.
JPN
Old Jan 11, 2009 | 09:23 PM
Psaboic's Avatar
Try spraying some belt dressing on it as a temporary fix. Spray it CAREFULLY when it starts squeaking while the motor is idling.
kags1969
Jun 24, 2010 03:24 PM
iscwebe
Feb 9, 2010 12:50 AM
reedkm
Sep 22, 2009 07:42 PM
boulwie
Dec 23, 2007 11:41 AM
