Blower Fan wont stop!!!
Hi Guys,
I have a 1996 Volvo 850 GLT and a few days back, my heater blower motor automatically jumped to the highest speed and won't stop running even after I shut the ignition off and take the keys out. I had to take the fuse off (for blower speed 4) in order for the fan to shut off. I am not sure what the problem could be. Need help diagnosing!! .Your answers will be greatly appreciated.Thanks in advance. |
RE: Blower Fan wont stop!!!
Do you have Electronic Climate Control (ECC)? If so, what mode was this in? If in AUT mode, my guess is that your ECC Resistor has gone bad. Generally when that happens, it's best to replace the resistor as well as the blower motor. If you want to limp by, you can not use AUT mode and manually adjust the climate control. I did this for about a month until I had time to install the new equipment. It took me less than an hour to fix.
If this is the case, expect it not to be cheap. Blower motors with cages run about $139 and the resistor is around $100 - AB |
Thanks for the quick response B1mmer. I don't think it was on AUT mode when it happened. We usually don't use AUT mode. I did notice the lights under AUT mode blinking when i first started the car for a few months. I suppose it could have been going and was trying to let me know? What does the ECC resistor look like and where is it located? Is there a resistor for manual climate control also. If so, could the manual Climate control resistor have gone bad? Thanks again for the help.
"A friend in need is a friend indeed". |
If you had lights blinking that means that a code was set. See if you can get the codes pulled.
Can you turn anything else on when the car is off that should be on like the radio or the head lights? [align=left] [/align] |
No. Everything shuts off except for the fan blower motor on the high position. Thanks!
Does your blower work on any speed, or just on high? If the latter, the resistor will need to be replaced. It's located (near the blower), behind the glovebox. It's fairly big, 4" long with a base of about 2" square, which surprised me when I received it :). - AB
It indeed was the Resistor!! Got the resistor for $15 from a junkyard and it worked. I would like to thank you and everyone else very much for your advice!! I love this forum!!!It is too good to be true!!
THANK YOU :) |
hey, hoping posting in here will bump to the top... Anyway, im thinking my blower resistor is gone, and the motor is on its way, but i want to make sure before i spend the money to replace... Ive got a 96 850, the blower will not stop running while headlights/runners are on, but if i turn them off the motor shuts off about 2 seconds after i kill the lights. The lights flash, and im going to check codes today again, last time i saw nothing... Anyway, the motor still blows air but not as hard as i think it once did, so maybe i can still save it.. I also found that the heat controls for the passenger side work, but the driver's side would take some fiddling with (some turning it down and up several times, some swearing, a lovetap or two) and i got it to blow hot air again. I cant get it able to blow on my legs, regarldess of what the control tells me, does change betweeen windshield and face, if i turn the knob.. The a/c does also not work, i believe this is the evaporator, b/c thats what the guy who sold me the car said, i think this summer ill actually get to fixing it (thanks for that writeup on how to do it tech). Would that have anything to do with it? It seems to me that the reisistor is gone, but occasionally the fan will go to a lower speed if i have it on it, but usually the headlights on=fan at highest speed. The weird thing for me is the whole headlights are a switch part, anychance its a ground problem instead? its also ecc
thanks |
Do you have ECC or MCC?
its ECC
On a related note, my AC climte control flashes lights. Which apparently means there is a code. How do I decipher the flashing to make a code out?? The old box I replaced 2 months ago since I broke one of the switches but I wasn"t able to reset that?
The codes need to be cleared with a scanner.
To the original poster the Climate module might be bad as well. I have seen the exact same problem with one burned out. You can pop it out and smell it and see if it is burnt. |
just pull out the whole ecc assembly in the dash? also how do i read the codes for it. Ive gone to autozone, scanned and it tells me everything is fine, but the rec and ac lights flash most of the time, which i thought indicated a code should be there..
If you pull the radio out you can reach up and push the ECC out from the back. I would cover your wrist with a rag though. Sometimes when it lets go it can cut your wrist on the dash.
You will need to get either a Volvo specialist or the Dealer to read the codes. |
ok i just replaced the resistor fuse and the blower motor now when i plug in the blower motor it starts to run all by itself no key at all in the ignition could the whole resistor be bad
i have a 1994 volvo 850 wagon just replaced the resistor fuse and blower motor BUT now when i plug the blower motor plug it starts up by itself no key even in the ignition it doesnt have ecc in it could the resistor itself be bad cause even if its un-pluged blower motor still works any ideas any help would be much appreciated
