Blower motor issue, again!
Old Dec 10, 2009 | 03:25 AM
kelsodatrini's Avatar
Default Blower motor issue, again!
Searched to make sure not a repost but sorry if so!
Okay guys so here's what happens despite being in a an El nino, it is still suuper cold here in this part of Canada, around -17F without the windchill, so my new but now squeaky blower motor decided to call it quits today so it seems. When i switched my ECC unit to full blast it or (on) i hear a click like a relay or something, but no power it was too cold to test any power snd i was in a rush, i ripped my dash apart, swapped the resistor but i'm not sure if this resisitor was good, it might have been blown or whatever, and still the same "click" but no power, car is going in for new turbo, intercooler etc but i dont wanna have to pay for this, as i replaced it last winter? any idea to the click? resistor? is there a relay? i need to fix it sooon sick of this,
I should have saved and bought a newer volvo as i'm just dishing the cash out for this thing, love it, but seriously new blower again this year or well something blower related, i need to not freeze, thank you :P
thanks in advance,
Kelsey
Old Dec 11, 2009 | 01:21 AM
Does anyone have any idea? similar problem or what not, taking the car in to the volvo mechanic tomorrow and i was just wondering if there was anything i could pick up get, or do in order to solve this before I had to fork out some more cash, i normally fix this myself but its too darn cold out!! :P
Thanks, Kelsey
Old Dec 11, 2009 | 08:13 AM
fcpgroton's Avatar
Former Sponsor
Are the REC and AC lights blinking? You can check to see if there are any codes in the ECC by reading the codes from the section B. If there are no codes, you are going to need to see if the blower motor is getting any power.
Old Dec 11, 2009 | 02:08 PM
Yes they are flashing weren;t at first, but are now, is that check through OBD? because i would have but my code reader is at work, but alright, yeah will check for power today, ugh, if the sqeaky motor kept rubbing and got stuck and it kept being powered to spoin, would it blow a fuse or anything??
Thanks
Old Dec 15, 2009 | 10:08 AM
madhader's Avatar
Sounds like your blower motor is shot. You need to test it to see if its getting power. Usually, if its the resistor the fan won't work unless you put it on the highest setting, and that doesn't seem to be the case, based on your diagnostic. Good news is that you can buy just the blower motor without having to buy the cage assembly. Think its like $70 online.
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
ProStreetDriver
Mar 17, 2013 08:31 PM
dsoelter
Feb 2, 2012 05:29 PM
W35
Dec 16, 2008 09:40 PM
crystalfleet
Jan 16, 2008 07:30 PM
