Blower motor working sporadically?
Old Sep 13, 2010 | 10:08 AM
grigalid's Avatar
Default Blower motor working sporadically?
I have a '96 850 non-turbo with an ECC blower control.
The blower will work one minute and not the next. I went a week without it (didn't check to see if it worked frequently) and now it works again. This has happened several times.
Any ideas?
Obviously there could be a loose wire somewhere which is going to be a nightmare to track down, but I was wondering if there was something else that could cause such sporadic behavior?
thanks
Old Sep 13, 2010 | 11:50 AM
beckmjea's Avatar
I am having the exact same problem with my '95 850 turbo. Hopefully someone has some suggestions.
Old Sep 15, 2010 | 10:40 AM
grigalid's Avatar
anyone have anything??
Old Sep 15, 2010 | 04:03 PM
regime's Avatar
Im not sure if there is one, or even where it would be, but it sounds like it could be a relay issue to me....
Just a stab in the dark though...
Old Sep 15, 2010 | 09:05 PM
timwu12's Avatar
i had this same problem about 6 months ago. try and replace the blower motor resistor unit. Those tend to fail over time, and that's exactly what happened to me. It's very easy to get to and replacing it takes like 15 min.
here's a link to a site that'll tell you how to do it:
http://volvospeed.com/vs_forum/index...guide-850sv70/
Old Sep 16, 2010 | 06:59 AM
grigalid's Avatar
Is this for an MCC or ECC, in other words does your fan have a 1,2,3 and 4 setting?
Thanks
Old Sep 16, 2010 | 01:03 PM
timwu12's Avatar
this is for the MCC, mine has the 1, 2, 3, 4 settins. The ECC's resistor unit doesn't look like that, those'll have a huge heatsink on it.
Just for reference:
ECC looks like this: http://www.fcpgroton.com/product-exe...category_id/78
MCC (the one for the 1, 2, 3, 4 setting) looks like this: http://www.fcpgroton.com/product-exe...category_id/78
Old Sep 16, 2010 | 02:33 PM
grigalid's Avatar
Just for reference:
So do you think it could still be a faulty resistor unit if i have an ECC system?
Old Sep 16, 2010 | 11:26 PM
timwu12's Avatar
that, i don't know, but it might be worth a try since a thermal fuse replacement on the resistor unit is like $2 from radio shack
fourbi4rox
Dec 28, 2012 12:23 PM
AndyXC70
2001-2013 model year XC70
Jun 18, 2012 08:14 PM
flip64
Nov 27, 2011 01:56 PM
Vmax
Oct 1, 2010 06:18 PM
sarahshamus
Aug 28, 2007 09:47 AM
