Blowing oil from the fill cap on my 94 850
Old 11-22-2007 | 05:02 PM
Trapper's Avatar
Default Blowing oil from the fill cap on my 94 850
I have seen discussion and suggested repairs to the PCV when oil is leaking heavy from the oil fill cap. Has anyone had success with the replacement of the system in stopping the leak?
Old 11-22-2007 | 06:52 PM
jks2's Avatar
Default RE: Blowing oil from the fill cap on my 94 850
Haven't done it myself but if you search the site I think you'll find that in many instances it has corrected the problem.
Old 11-22-2007 | 06:57 PM
JPN's Avatar
JPN
And should you decide to service it, here are two vendors many of us have been using:
http://www.fcpgroton.com/volvo.htm#850
http://www.eeuroparts.com/home.aspx
Note, that Turbo and Non-turbo use different kits. Also, the illustrations may be backward, as someone has noted in the past. Check your model year & VIN too just in case.
You also need intake manifold gasket upon PCV servicing, as you need to disconnect the manifold. I would also order filler cap gasket + dipstick O-ring.
I hope this helps.
JPN
Old 11-23-2007 | 02:02 AM
tripleb's Avatar
First of all, the cap seals need to be replaced every 30k at least. They will get hard and leak oil all over the top of the head and down the sides of the engine if left alone. You should be able to bend the seal without it cracking.
B
MikeMac
01-04-2015 10:24 PM
angusjustice
08-30-2010 01:03 PM
dads 740 turbo
11-13-2008 01:14 AM
jeannelw
11-18-2005 11:05 PM
bli745
03-10-2005 01:20 PM
