brake light on after bleed
changed my rear driver caliper tonight and after bleeding the brakes, the light came on... any suggestions? I didnt touch anything except the MC and bleed screws..
the wires on teh cap look to be in place and there is pleanty of fluid in the MC?
There's no point for a pressure measurement in the fluid reservoir as it isn't pressurized until after it goes through the master cylinder. System is also doesn't have any pressure until the brakes are applied which would mean the light goes on and off depending on brake actuation.
Hello Mr. Rejeep,
Sorry to hear about such nuisance. Funny, I had a similar situation with coolant reservoir level sensor, after installing a new tank. I just took the original sensor probe off the original tank and put it on the new tank, and the low level light on the dash was on regardless of the coolant level. I concluded that the magnetic float in the new tank was stronger than the original, activating the probe from further distance than the original. I have to buy a new sensor probe as I've dissected it, about $20 for such a simple device.
Anyway, low fluid level should not cause pressure changes as Mr. info2x said, unless the fluid is absent from the reservoir. Fluid level drops according to the wear on pads, and some mechanics top off the reservoir unnecessarily.
If the float moves up & down, the circuit is shorted. A shorted circuit turns the dash light on regardless of the fluid level, as the circuit is closed all the time. I would try to take the cap off, cover the reservoir with plastic wrap and put a rubber band around it, and inspect the cap for exposed or kinked wires/metallic foreign objects, etc...
Good luck,
JPN
Good luck,
JPN
red8812
Nov 13, 2012 09:38 AM
Beemer2002
Jan 4, 2010 08:14 PM
