brake pedal sensor
Is the brake pedal sensor interchangeable between years? My 94 needs a new one and I can get one from a 93. The part number is different unless the guy has the wrong sensor identified. He's parting one out online. Is it worthwhile to just get a new one since it sounds like the go often enough?
If you can solder they are an easy fix, pop apart solder pc board, silastic top, put together and you are done, saving $$$$
Take a look at this : https://volvoforums.com/forum/showth...highlight=arzy
