Brakes
Old Jul 10, 2007 | 06:04 PM
volvodrummer's Avatar
Default Brakes
i need to replace my brakes..... any reccomondations?
Old Jul 11, 2007 | 02:46 AM
JPN's Avatar
JPN
Default RE: Brakes
Hello VD,
Here's a copy & paste from the following thread:
https://volvoforums.com/m_48928/tm.htm
BRAKES:
Brakes on 850 are straightforward, here's the parts you'll need:
GENERAL:
*1. DOT-4 Fluid (I used ATE's Super Blue Racing).
2. Silicone-based grease or CV-joint grease for anti-squeak purpose.
3. A can or 2 of brake cleaner spray.
4. Large C-clamp, 10WR Vise-grip or piston pushback tool to push back the piston.
5. Sandpaper to clean rusty spots (use oil/WD-40 for sanding).
*I used Motive Product's One-person bleeder and flushed the system by myself. Available at FCP Groton/Motive Products.
FRONT:
1. New rotors (Zimmermann, ATE, Brembo or any OEM).
2. New pads (Genuine Volvo, Textar (OEM) orany high-quality ceramic pads).
3. Synthetic grease for slider pins (The pins are hex (allen) bolts).
4. New caliper bracket bolts.
5. Bungee cord to hang the caliper.
*If calipers look too worn, you may want to buy rebuilt calipers loaded with OEM pads.
REAR:
1. Rotor (same as above)
2. Pads (same as above, I used Roulands-Dan Block OEM pads)
3. New caliper bolts.
4. New hardware (Retainer springs & pins by Scan-tech Sweden).
5. New shims (half-size shims are highly recommended to stop squeak & low-tone drone).
Most of the parts can be bought at:
http://www.fcpgroton.com/volvo850brakes.htm
I hope this helps. Make sure to keep safety in mind.
JPN
Old Jul 11, 2007 | 10:00 AM
white out's Avatar
Default RE: Brakes
how much money do you want to spend?
Nick
Old Jul 11, 2007 | 11:48 AM
JimKW's Avatar
Default RE: Brakes
Just do all OEM parts. You can get them from fcpgroton fairly reasonably. Brembo rotor for about $40 each are fine, but use OEM pads.
Old Jul 11, 2007 | 12:34 PM
RedTurbo850's Avatar
Default RE: Brakes
Parts Train is cheaper, but some of the descriptions are kind of confusing...
Try eEuroParts too...I hear they price match, but i'm not sure.
And what do you mean by "replacing your brakes"? Pads? Rotors? Caliper?
Pads - Mintex are cheap. Mintex in front and OEM rear or just Mintex/Mintex.
Rotors - Brembo (No diff, but its cool to have the brand).
Caliper -any
Old Jul 11, 2007 | 03:06 PM
JimKW's Avatar
Default RE: Brakes
Any time I have tried anything but OEM pads, my brakes squeal. I can't stand squealing brakes, so I use nothing but OEM pads. I also have dirty wheels because of brake dust, but that's the price I pay for being able to stop and not listen to squealing brakes. Tech says OEM too.
Old Jul 11, 2007 | 04:27 PM
Rev's Avatar
Rev
Default RE: Brakes
I put Brembo rotors all around, with OEM pads up front, and Bendix pads up rear. Valvoline DOT4 synthetic brake fluid, and plenty anti-squeal. Brakes are strong!
netconcepts
Feb 10, 2005 08:51 PM
Air Defender
Jan 29, 2005 07:45 PM
djbaines
Nov 10, 2004 06:43 PM
jhenry83
Aug 31, 2004 05:57 PM
midnight
Jun 29, 2004 05:51 PM
