-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Broke my son's '96 GLX - Won't crank (https://volvoforums.com/forum/volvo-850-16/broke-my-sons-96-glx-wont-crank-65072/)
zoolan70 Aug 17, 2012 10:03 PM
I bought my son a 1996 GLX from a trusted friend for his first car. Unfortunately, neither he nor I know how to drive a manual transmission. A family friend was teaching me how to drive it, and after a few stalls, I was starting to get the hang of it.
Then I did something that was probably not good. I forgot to press the clutch in after I stalled it, and tried to start it in gear. It lurched and stalled.
From that point on, it will not turn over. I've done some testing, and can confirm that I get 12 volts to the large wire on the starter when the key is set to 'run' and 12 volts to the small wire when the key is turned and held on start. I've attempted to whack the starter with a hammer but no luck as well.
Any thoughts on what the issue could be, or things I could try next?
Thanks!
slimflex2 Aug 17, 2012 11:01 PM
anyone on here with a manual transmission experience?
Brick850 Aug 18, 2012 04:40 AM
Try putting it in gear and rocking it back and forth by hand to turn the motor a little? That is how I used to free up my starter motor.
zoolan70 Aug 19, 2012 01:56 PM
Fixed it. The ground wire on the starter was fried. Put a new starter in, and it works like a charm!
slimflex2 Aug 19, 2012 09:37 PM
good to know you fixed it. lesson learnt.LOL
