Buying advice? 94 w/ 180K, 5spd, some issues...
Old Jan 17, 2010 | 08:54 PM
tonyfolenta's Avatar
Question Buying advice? 94 w/ 180K, 5spd, some issues...
Having never before considered a Volvo, I found one for a decent price and I'm definitely giving it new thought. I'm looking at a 1994 850 with about 180k miles. It's a 5-speed standard sedan, non-turbo, in (mechanically) decent condition. After taking it for a drive and looking it over, here's what I've noticed:
- Heater: only works at speed 4, makes HORRIBLE spinning/knocking/grinding noise, sounds like the motor/fan assembly is way out of whack, however it does produce heat just fine
- Hood: latch seems to be broken? There's a little hook sticking out of the grille that the owner uses to pull it open... seems odd, but it works
- Driver's side mirror: broken; casing is there but lens is falling out, duct-taped at the moment =P
- Headlights: one seems temperamental, sometimes works, sometimes doesn't; probably needs a new bulb, or is it something worse? is it hard to work on?
Here's the listing: http://rochester.craigslist.org/cto/1552339124.html
So, of the problems I've noted, what are your thoughts? Worth fixing? About how much might parts cost? Is the heater a DIY job? I'm not a mechanic, but I'm no stranger to the underside of a dash.
After the drive, I noted two things: it handles beautifully, and it's one of the most comfortable cars I've driven. The guy is willing to take $1100 or so for it, but repairs (heater is most important at the moment) can't go much higher than $4-500 on my budget. What do you all think?
Old Jan 17, 2010 | 09:16 PM
vpatrol's Avatar
don't sound like big problems to me but I'd wait for someone who's experienced them before commenting on ease and cheapness of repair
The hood release is a little hook that pops out through the grille. That's standard unless your one is bodged up a bit.
Sounds like a decent deal
Old Jan 18, 2010 | 05:55 PM
_HighVoltage_'s Avatar
The hood latch costs less than $10 and you can replace it in under 2 minutes.
The headlight...it might be a loose connection. When I changed the bulbs on my '94, one of the wire plugs literally disintegrated in my hands.
Other things that you need to consider/check:
- check the engine number, or the manufacture date of the car - you really want it to be past April 1994, because the models prior to it use the 93 hardware which is a bit quirky.
- timing belt - when was it done?
- PCV system - ask the owner, and also pull out the dipstick - is there smoke?
- check for leaks, if it has a leaking rear main seal, you can easily spot it. just drive the car for 15 minutes park it and look under it after a few minutes.
- check the seat recliner - it is common for the cable to break and the seat stops reclining. Not a deal breaker though...
Good luck!
Old Jan 18, 2010 | 06:37 PM
As for the PCV system, pull the dip stick while the car is running. Smoke comes out if it is plugged up.
Sounds like a fair deal to me. Double check the manufacture date.
Old Jan 19, 2010 | 09:54 AM
fcpgroton's Avatar
Former Sponsor
I would agree, this car does not sound like it would be much work to get it all straightened out. I would get it if I were you.
VancetheVolvo
Feb 15, 2015 08:01 PM
snowdernsons
Jun 5, 2011 10:03 AM
snowdernsons
Jun 4, 2011 08:10 PM
texan_176
Aug 31, 2009 08:46 PM
onnoff7
Aug 19, 2009 04:58 AM
