A/C Does Not Cool Good When HOT
Old Jun 16, 2010 | 12:25 PM
  #21
I had a used compressor put in my T-5R last spring after I got it and it worked good for about 60 days. Then it started cyceling. My favorite A/C shop said that compressor was leaking so I went back to the guy that installed the used compressor and they serviced it for free with leak detector (dye). Two months later it was 1/2 working again. Just like you said, great at 85 or below, not worth a dang over that. It gets 105 almost every day here in July & August so A/C is a must, all day and night. So I went back and they serviced it again and claimed they could not find a leak. Said glowing area looked like old dye (whatever). So they cleaned it all off with some special cleaner and off I went. They also showed me how to check the evaperator coil.
So I went to the store and picked up my own leak detection kit (light & goggles). When it started cyceling again I started hunting for the leak and low and behold my evaperator was leaking and there was some spots on the compressor. So I figured I needed to replace the evaperator. Being that it was in October and I was recovering from my daughters college tuition, I didn't hurt myself to get another one.
So now it's spring, getting hot, and no cash for a new evaporator. So I was in O'Railly's and notice the A/C service stuff there. The guy at the register talked me into getting the large can of synthetic stuff that had the hose & guage on it. It also had some STOP LEAK in it. I hooked it up and emptied the can. Started cyceling and pressure was still a little low so I went back and got a small can (I think it's 12 oz) and emptied that in there. That was about a month ago (mid May 2010) and it still blows 100% cold and does not cycle.
I think the system could have been totally empty when I started and now has enough to keep it going properly. NO A/C is not an option for me. I'd rather stay home and let the world end than to drive around sweating like a pig in my car. The A/C works great in the 960 so I would just drive it.
I will post back when and if it starts cyceling again. I am not sure if the stop leak actually would stop leaks in the evaperator. From what I have read, it is to help expand seals, not stop leaks in the evaperator coil. I still want to fix the car but just need to get the extra cash for the parts.
Old Jun 20, 2010 | 09:09 AM
  #22
JimKW's Avatar
The other day I turned it on and the compressor ran for maybe 30 seconds then started cycling again. It's not cooling at all now. Guess I'm going to have to take it somewhere.
geoworley
South
Jan 16, 2014 03:53 PM
mstrplmber
Jun 26, 2010 04:10 PM
beardo265
Sep 27, 2007 09:24 AM
Eric
Jan 19, 2006 08:41 PM
