a/c help
Old Jun 24, 2009 | 03:14 PM
theescovedos's Avatar
Default a/c help
My a/c will come on for about 2 minutes and then start blowing warm air...it will not come back on until engine has cooled down.
Old Jun 24, 2009 | 08:48 PM
Likely is low on freon. Have it done by a pro, not worth destroying the system over charging it because most places will charge $900 to replace the compressor.
If the freon is properly serviced and you still have a problem, it is likely some washers in the compressor clutch that needs to be replaced. You can search the sticky post to read more about that.
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
