Car just made a weird noise...
Old 07-23-2009, 01:38 PM
Saleen9090's Avatar
Originally Posted by gilber33
Are they all on a circuit or something? Hm, well maybe then it's just the speaker, because all the other speakers work, I really hope the rear drivers side door speaker works. I would hate to have to mess with the harness. How are the wires split up in the back? do they just splice somewhere and then go to the separate speakers?
They are not on a circuit... Maybe its just a "thing" with my head unit ya know?
Anyway, There should be seperate wires for both speakers. Each speaker in the car has it's own set of wires running out of the head unit.
  #22
Old 07-23-2009, 01:53 PM
gilber33's Avatar
But wouldn't wouldn't each front set of speakers have a crossover for the tweeter/woofer?
  #23
Old 07-23-2009, 02:01 PM
gilber33's Avatar
Your right, each speaker has it's own set of wires going to it, in the front. I found a diagram for the plugs, but it only mentioned one rear left and right speaker. It didn't say left rear and left rear door, just left rear, etc.
http://volvospeed.com/Repair/radiocon.php
Maybe I just misread it. But if that's the case. How do the rear speakers hook up?
  #24
Old 07-23-2009, 02:21 PM
gilber33's Avatar
Now I have another question. In the sedans, there is a tweeter in in the dash and a speaker in the front door. There are obviously speakers on the rear deck by the rear window, but are there speakers in the rear doors????? The wiring gram only shows one set of rear speakers.
  #25
Old 07-23-2009, 02:35 PM
Saleen9090's Avatar
Maybe the left rear door and deck are on circuit, not sure tho.
Really shouldn't matter for you though. Your speaker probably just got unplugged. An easy fix though seeing as you can access from the trunk.
I took out the tweeters in the dash... They sounded like sh*t. Instead now, that opening on the drivers side allows me to wire my boost gauge secretly. lol
  #26
Old 07-23-2009, 02:51 PM
gilber33's Avatar
That's what I'm thinking. I don't know how else they could be. I hope I can get it working, I would hate to have to go in there and start re-wiring all this.
  #27
Old 07-23-2009, 05:56 PM
gilber33's Avatar
I'm pretty sure it's my harness. Neither of my driver's side rear speakers work and I pulled out the deck speaker and there's no way one of the speaker wires could have just come loose and fallen out. Although my harness appears to be fine, it must have been pulled just enough to have broken the connection. So, I am going to order a new harness and hope that that solves the problem.
  #28
Old 07-24-2009, 09:57 AM
HTRD2B's Avatar
I have a 93 and I have had both the tweeters out of the dash and both rear deck speakers unplugged from the vehicle for a while and the others (that are not blown) work just fine. I would check the connection at all the speakers, the amp, and at the rear of your head unit before ordering a harness. Yes, there are a total of 8 speakers in your car, 2 dash, 1 in each door, and the 2 rear deck.
  #29
Old 07-24-2009, 10:02 AM
gilber33's Avatar
But neither rear driver speakers work and the rear deck one was plugged in, so even if that one was unplugged the door speaker should still work. My stereo was recently stolen out of my car, so I'm guessing that when they ripped it out, they had pulled the harness and must have messed up the connections.
swiftjustice44
10-25-2012 06:32 AM
vfgilber
11-22-2009 06:40 PM
jw02s80t6
03-17-2009 08:30 PM
showcar
09-20-2008 04:36 PM
Quick Reply: Car just made a weird noise...
