CD player no response.
Old Apr 2, 2006 | 12:16 AM
revdevil's Avatar
Default CD player no response.
I don't think its the remote unit. Any idea on how to check the radio up front. I press the CD function button and get nothing. Plug/unplug the trunk unit nothing still.
Thanks,
Revdevil
Old Apr 2, 2006 | 12:28 AM
Default RE: CD player no response.
Do you have power at the C/D changer?
If you have the radio code uplug the radio and let it sit for a couple then plug it in and try.
Old Apr 2, 2006 | 04:44 PM
billofdurham's Avatar
Just had a similar problem with my Alpine CD changer running through a Volvo SC801 head unit.
When I bought the car the unit would not play disc 6 but played the other 5 without problem.
One day the dreaded EEEE appeared on the screen and the changer stopped working. Radio and tape were OK. CD button did nothing. I disconnected the lead at the changer and reconnected - nothing. I then took the changer into the front of the car and connected it direct to the interface - nothing, but it ruled out a cable fault.
Yesterday I received a new (used) changer from eBay, connected that - nothing. The air turned a delicate shade of blue, believe me. The new changer included an interface which was different to that fitted to the car so I changed the interface but found it had one more wire than the original and I was not too sure where the extra wire went. Back went the original interface and the new changer came to life and I was able to play CDs. Out of curiosity I unplugged the new changer and plugged in the original and it came to life and I was able to play CDs - including disc 6.
As I had unplugged the changer from the cable but had not unplugged the interface from the rear of the head unit until I tried to change the interface I can only assume that the problem concerned the interface and its connection to the rear of the head unit. It's worth a try.
Good luck.
Bill.
1995 850GLT Estate.
Old Apr 3, 2006 | 10:02 PM
revdevil's Avatar
Thanks Bill. A while back I had the EEEEEE and unplugged the remote unit and it worked for another month then went dead again. Tried the same thing this time but nothing....
I'll try the interface.....
bjblackmore
Jun 25, 2012 10:44 PM
robv70
Jul 5, 2008 06:44 AM
vetalbig
Jan 22, 2008 01:19 PM
1996850turbo
Jul 26, 2007 02:36 PM
740_in_TX
May 25, 2006 08:54 PM
