CEL P0172 still after O2 sensor/MAF repalced
Old Oct 18, 2007 | 07:27 PM
cpak007's Avatar
Default CEL P0172 still after O2 sensor/MAF repalced
I purchased theAutotap OBDII to troubleshoot this CEL on 1997 850 GLT wagon and attached a read outhere (I spent too much already and I don't want to give it up yet)
I replaced a MAF and O2 sensor before Cat but not the one after Cat.
I am guessing it might be fuel injector is leaking because Long term feul trim ration is -7.8% (I learned it from one of website)
or something I missed here?
I check the vacuum hoses and all of connections and it looks good.
Do you have any idea on how to check fuel injectors
Thank you for yourhelp in advance.
[IMG]local://upfiles/10051/82D267426F7841739BDA12A8BD6CB4A7.gif[/IMG]
[IMG]local://upfiles/10051/67C9F042447D487890926C021642098A.gif[/IMG]
Old Oct 18, 2007 | 08:40 PM
Default RE: CEL P0172 still after O2 sensor/MAF repalced
Is the Rear O2 sensor sweeping at all?
Old Oct 18, 2007 | 10:16 PM
cpak007's Avatar
The Rear O2 sensor respond slower than front one according to AutoTap feedback
(I am guessing sensor 1 as front (before Cat) and Rear one as sensor 2 (after cat)
Rear O2 sensor is old.
Could you explain how control module respond from rear O2 sensors feedback.
Thanks again
Old Oct 18, 2007 | 10:45 PM
tripleb's Avatar
The rear 02 sensor shouldn't sweep at the same rate like a front sensor does. It is for long term fuel trim, so the rear sensor could be faulty, but I don't have experience with these Auto Tap readings.
You really need to spend some time with several good cars to really get an idea as to what reading are normal. I've spend many hours with the Volvo Scan Tool and I came to realize that some readings are useful and some are plain useless.
I didn't see the code, what was it? Is it still present?
B
Old Oct 19, 2007 | 08:14 AM
cpak007's Avatar
CEL code is P0172 (Long term fuel trim rich but only -7.9%) that I attached at my first message.
Comparing with other car read out is really a good idea
Thanks
Old Oct 19, 2007 | 08:43 AM
axelm's Avatar
Why don't you clean the rear O2 sensor and measure it again?
Old Oct 19, 2007 | 01:46 PM
cpak007's Avatar
Cleaning O2 sensor is another good idea too
I will do it over the weekend andwill postthe resulthere
Thanks for all of your help
Old Dec 2, 2007 | 09:41 AM
Svtfiveoh's Avatar
im getting the same code.. I cleaned the MAF sensor but it came back.. How do you clean the rear 02?
Old Dec 2, 2007 | 04:49 PM
axelm's Avatar
http://forums.bimmerforums.com/forum...d.php?t=324738
Old Dec 8, 2007 | 09:04 PM
cpak007's Avatar
Default I found culprit RE: CEL P0172 still after O2 sensor/MAF repalced
I found the culprit of CEL P0172 (Long Term fuel rich)
I have been working this one forabout 6 months on spare time (afew of hours per month) and replaceda MAF, an O2 sensor(front one) swapped old frontO2 sensor to rear after I modified wire lengths but it wassame CEL after a couple of drive.
I should listened"TECH"'s advice more seriouslywhen he recommend to check the vacuum line
Actually I spent a lot of timeforvacuum leak but Icouldn't find it until last week
Some mechanic mentioned to me to check the Thermostat, during theThermostat/Water Temp sensor investigation I noticed a vacuum line was hidden between power steering assy and intake manifold and was broken.This vacuum line was hard to reach without a lot of parts remove, so instead Ire-routed the end to other end with $3.00 vacuum line from Aut0Zone
Attached pictures for Ref
Thanks
[IMG]local://upfiles/10051/356ECA5FA45445728EB068648660B303.jpg[/IMG]
[IMG]local://upfiles/10051/1D43DF7071BB421487CA3712CE9ED370.jpg[/IMG]
Old Dec 8, 2007 | 09:36 PM
Default RE: I found culprit RE: CEL P0172 still after O2 sensor/MAF repalced
Glad you got it figured out.
Old Sep 4, 2008 | 07:23 PM
rmendoza's Avatar
I have the same problem hose. That hose goes from where to where? Thanks.
NFrank89
Aug 26, 2011 07:53 PM
02VolvoS40
Jul 16, 2010 08:12 PM
schigara
Dec 12, 2009 03:21 PM
tenchu
Apr 20, 2008 12:17 PM
cpak007
May 12, 2007 06:13 PM
