Check engine light
95 850 Turbo my check engine light came on, pulled the codes reading 232.
Exhaust smellpretty strong and greyish. Any suggestions? Thanks. |
RE: Check engine light
232 means long term fuel trim. Means a vaccum leak somewhere or something like that.
pardon my ignorance
so can someone explain why a vacuumn leak would make the exhaust smoke? thanks. |
It could cause the engine to run rich and the smoke you are seeing/smelling is unburnt fuel
ORIGINAL: Psaboic It could cause the engine to run rich and the smoke you are seeing/smelling is unburnt fuel |
thanks.
just wanted to give an update on my code P0440 I was running.
Checked all the vacuumn lines this weekendand the problem turned out to be a clogged tube (not sure of the name) that goes from the air filter, black rubber and about 2ft long. Cleaned it out full of leaves, reset the error codes and the check engine light disappeared. Anyone know the name of this rubber tube? |
Glad it is fixed!
tiny black rubber tube connected to air filter and ???
Originally Posted by Aftermidnight
(Post 107959)
problem
