Check engine light
Old Jun 9, 2008 | 09:02 PM
Aftermidnight's Avatar
Default Check engine light
95 850 Turbo my check engine light came on, pulled the codes reading 232.
Exhaust smellpretty strong and greyish. Any suggestions? Thanks.
Old Jun 9, 2008 | 10:32 PM
Default RE: Check engine light
232 means long term fuel trim. Means a vaccum leak somewhere or something like that.
Old Jun 9, 2008 | 11:59 PM
pardon my ignorance
so can someone explain why a vacuumn leak would make the exhaust smoke?
thanks.
Old Jun 10, 2008 | 08:42 AM
Psaboic's Avatar
It could cause the engine to run rich and the smoke you are seeing/smelling is unburnt fuel
Old Jun 10, 2008 | 06:32 PM
ORIGINAL: Psaboic
+1
Old Jun 10, 2008 | 09:13 PM
thanks.
Old Jun 22, 2008 | 09:44 PM
just wanted to give an update on my code P0440 I was running.
Checked all the vacuumn lines this weekendand the problem
turned out to be a clogged tube (not sure of the name) that
goes from the air filter, black rubber and about 2ft long.
Cleaned it out full of leaves, reset the error codes and the check
engine light disappeared. Anyone know the name of this rubber tube?
Old Jun 23, 2008 | 08:38 AM
Psaboic's Avatar
Glad it is fixed!
Old Aug 2, 2010 | 01:07 AM
oreng's Avatar
Default tiny black rubber tube connected to air filter and ???
Originally Posted by Aftermidnight
problem
does this black rubber tube that's connected to the air filter (right next to a slightly larger off-white tube) also connect to somewhere else? what is this black tube? i found the other end not connected to anything.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
