CLICKITY CLACK while turning.
Ok, 100k on my 96 850 glt n/a. CV joints? clickity clack while turning right or left. I'm not sure what to replace. Thanks for any input.
yep....cv joint. Jack it up and crawl under and it should be easy to tell which one. When the boot splits, the grease gets thrown all over everything. Find the mess and you'll find the bad joint.
Probably pay off to do both sides then you know your good for a long period into the future.
Don't forget to replace the axle seals if you pull the axles. Nothing more frustrating than having to go back in there in a couple thousand miles and pull the axle(s) if it starts leaking.
