Climate control issues, 94 850 Turbo
Hello all,
1994 850 Turbo Wagon, heat does not work neither does the defroster. I have electronic climate control and I have retrieved the following codes: 135 No signal from engine coolant temperature sensor. 231 Ventilation damper motor position sensor open circuit or shorted to 12 volts 233 Floor/defrost damper motor position sensor open circuit or shorted to 12 volts 323 Ventilation damper motor active too long 324 Floor/defrost damper motor active too long 411 Blower fan seized or drawing excessive current 414 Drivers side interior temperature sensor inlet fan seized 417 Passenger's side interior temperature inlet fan seized Ever since I owned the vehicle the AC/ recirculation lights would blink for a short duration upon start up. Recently I was driving on the freeway and I decided to turn on the blower to defrost the windshield, then I heard a faint click and the AC/recirculation lights started blinking (while I was driving) for a longer period of time, like twenty seconds or so. I have considered the notion that I have more than one issue going on here. Can anyone say something about the codes that have been thrown? I disconnected the battery and got the same codes again. I am just thinking it is a blower motor...I hope? Thanks in advance. |
