Climate control issues, 94 850 Turbo
Old Dec 19, 2010 | 01:21 AM
matthew.lemke@gmail.com's Avatar
Default Climate control issues, 94 850 Turbo
Hello all,
1994 850 Turbo Wagon, heat does not work neither does the defroster. I have electronic climate control and I have retrieved the following codes:
135 No signal from engine coolant temperature sensor.
231 Ventilation damper motor position sensor open circuit or shorted to
12 volts
233 Floor/defrost damper motor position sensor open circuit or shorted to
12 volts
323 Ventilation damper motor active too long
324 Floor/defrost damper motor active too long
411 Blower fan seized or drawing excessive current
414 Drivers side interior temperature sensor inlet fan seized
417 Passenger's side interior temperature inlet fan seized
Ever since I owned the vehicle the AC/ recirculation lights would blink for a short duration upon start up. Recently I was driving on the freeway and I decided to turn on the blower to defrost the windshield, then I heard a faint click and the AC/recirculation lights started blinking (while I was driving) for a longer period of time, like twenty seconds or so. I have considered the notion that I have more than one issue going on here. Can anyone say something about the codes that have been thrown? I disconnected the battery and got the same codes again. I am just thinking it is a blower motor...I hope? Thanks in advance.
wolfchoir
Jul 29, 2014 02:30 PM
jfikentscher
May 31, 2006 09:58 PM
vict8r
Oct 26, 2005 01:04 AM
