climate control no power
Old Jan 20, 2009 | 11:13 PM
pmatusas's Avatar
Default climate control no power
I have a 93 850 and I am sure that it is simple but i cant for the life of me figure out why I have no power to my climate controlI was wondering if there is some fuse or relay or something that is blown but I cant find anything
Old Jan 21, 2009 | 04:01 AM
JPN's Avatar
JPN
Default RE: climate control no power
I would first check 2 fuses for the blower (not sure if your 850 has the same set-up, but seems the same).
It could be:
- Blown fuses.
-Electrical connector inadvertently disconnected.
- The blower went south.
- Max speed relay failure?
See what others have to say.
JPN
[IMG]local://upfiles/6892/1ADA6F75A99B4AE39988DCBCA7FC1E2B.jpg[/IMG]
[IMG]local://upfiles/6892/DAA95385AA7B41B99933CD262A89111F.jpg[/IMG]
Old Jan 21, 2009 | 07:46 AM
If the fuses are good and you still have no power/lights on the module the module itself might be bad.
Also if you replace with a newer one you will need to make modifications.
Old Jan 21, 2009 | 07:55 AM
pmatusas's Avatar
i checked the fuses for the blower speeds 1-3 and 4 and they are good and have power going to them and I dont think it is the module because I connected a hot wire to one on the back and everything started working I still gotta try and get a new relay to see if thats the problem
Old Jan 21, 2009 | 09:43 PM
pmatusas's Avatar
It was the unit I took it out and took it apart and soon as i took off the cover seen right where it got burnt thanks for the help
Old Jan 22, 2009 | 02:48 AM
JPN's Avatar
JPN
May the unit rest in peace.
JPN
Old Nov 11, 2009 | 06:50 PM
bdruff's Avatar
How much was the new unit?
Old Nov 11, 2009 | 09:01 PM
They sell them on FGP, check there 1st. They sell 2 different motors.
Greg G
Nov 10, 2007 05:06 PM
jfikentscher
May 31, 2006 09:58 PM
JimKW
Feb 27, 2006 08:30 PM
tomservo
Mar 23, 2005 10:28 AM
watson6033
Feb 24, 2005 12:08 AM
