Code from A-2 154
Old Aug 5, 2007 | 08:00 PM
Luther White's Avatar
Default Code from A-2 154
Ok guys I pulled code from A-2...154. I just changed the PCV system (cleaned all ports and holes) intercooler hoses, vacuum lines, complete tune-up...rotor, wires, dist, plugs with mostley OEM.
Old Aug 5, 2007 | 08:09 PM
Default RE: Code from A-2 154
Did you clean the EGR valve when you had it apart?
Old Aug 5, 2007 | 08:12 PM
JPN's Avatar
JPN
Ok Luther I pulled my manual...A2:1-5-4 EGR System Leakage.
As Tech says, clean the EGR, check for proper vacuum hose connections at EGR Valve, clean the electrical connections with contact cleaner, then reset the ECU. If none of these helps, you may need a new EGR Valve.
Other than that, your 850 seems to be TLCed.
JPN
Old Aug 5, 2007 | 08:20 PM
Thanks guys once again with your fast responses. I did clean it... I spayed it with Deep Creep and roto rooter it out...maybe I messed it up. I read the manual and it refers to something call a themostatic vacuum switch, is that the evap valve or the control unit up on the top of the radiator? Damn 195.00 dollars for the EGR valve. This car is killing me. But when it runs it runs, right, lol!! How does one actually test the EGR valve....with a vac gauge??
Old Aug 5, 2007 | 08:36 PM
You would add vaccum to it and make sure it moves.
You removed the valve and cleaned the intake as well?
Old Aug 5, 2007 | 08:45 PM
Yes I cleaned all ports and holes. Thanks Tech I will check it out.
rspi
Nov 24, 2014 10:56 AM
Elsid
Sep 9, 2010 08:42 AM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
pitar
Aug 19, 2004 02:33 PM
