Code reader worked. Some engine problems. Help!
Old May 14, 2008 | 12:54 PM
LoganVolvosrock's Avatar
Default Code reader worked. Some engine problems. Help!
Ok thanks everyone for the help. The problem i am having with my car is i pulled it in the garage the other night, i go out to start it the next day and it just turns over and over and over. When i took the codes i got a bunch of useless information. my A6 which is the ignition gave me no readings was the only one to do nothing. checked the voltage and was getting 10 volts. i cleared all the other ports, and tryed to start my engine hoping for somemore codes got nothing. i am figuring that it may be the fuel pump but i dont know? its wierd that i got nothing from the ignition system. but i was wondering if i got a OBD II because i do have the port, if it would be able to return a ignition system code from there.
I have a 1994 850 turbo.
Thanks Logan
Old May 14, 2008 | 01:15 PM
axelm's Avatar
Default RE: Code reader worked. Some engine problems. Help!
Please don`t double post. Following up on the other thread will give you just as good support.
Lansdowne
Sep 22, 2014 01:02 AM
tekimp
Jan 24, 2009 08:22 PM
nunrgguy
Aug 5, 2007 09:34 PM
Beardog
Jun 30, 2007 12:53 AM
gullyg
Aug 21, 2006 08:54 PM
