Cold start won’t idle
Old Oct 2, 2022 | 10:46 PM
MURKSER's Avatar
Question Cold start won’t idle
97 850 takes several minutes to finally warm up enough to idle normally. This happens only when the car has not run for several hours I would say 8 to 10 hours.
i’m running the car on E 85.
Old Oct 3, 2022 | 01:07 PM
Did you test the ECT sensor? (should be around 3K ohms at 65F - higher if colder and drops to under 300 ohms when the engine is at operating temp)
Old Oct 7, 2022 | 11:50 AM
MURKSER's Avatar
Hmmmm, I won't to this test yet because I would have to remove the radiator hose to get to it.
Old Oct 11, 2022 | 06:16 AM
firebirdparts's Avatar
OBDII scan tool is the easy way. Just plug up and look at what temperature the car thinks it is. Then you can decide to agree or disagree with the car.
E85 is definitely a problem; it wants to run rich when cold, and it's not able to. There's no way it can adjust until the O2 sensor warms up. I would think you'll see a code for excessive fuel trim when it's in closed loop, but you be the judge there.
cxbeaver
Engine & Internal
Sep 14, 2019 07:22 AM
Johnny Volvo
Nov 27, 2012 01:05 PM
John Casey Mathena
Mar 13, 2012 07:18 AM
Crispin
Nov 5, 2007 09:04 AM
gary5461
Nov 28, 2005 09:23 PM
