Coolant Hose Replace
Old May 31, 2019 | 09:36 AM
RedSweed's Avatar
Default Coolant Hose Replace
As my 850 t5 gets closer to being 25 years old, I worry about the rubber hoses that moves coolant within my car. Is there a complete list of hoses, or a set online available for purchase for a complete replace? When I look at IPD or Rockauto, it they only seem to offer up to two hoses per purchase. I found this surprising as I though a complete replace was common.
Old May 31, 2019 | 07:44 PM
Try FCP Euro or EEuro Parts or Tasca parts to get a coolant system kit. There are the upper and lower radiator hoses, the hoses to/from the overflow tank which are normally in the kit plus all the correct clamps and you should do the ECT sensor, thermostat and the overflow cap as well. The only other hoses to consider are the hoses from the block to the heater core. The 850s always run coolant through the heater core (using the blend doors to turn the heat on and off) so but you'd need access to the heater core to get to the o-rings. At some point the heater core will likely start leaking slowly and that's a good time to do the core plus hoses and o-rings. Good news is the heater core replacement is easier on the 850 than most cars (pop off the center console sides and the core slides out to the passenger side...)
Old Jun 2, 2019 | 11:37 PM
RedSweed's Avatar
I already did the heater core last fall, but I'll take a look at those websites for the hoses.
Old Jun 6, 2019 | 07:42 PM
860ARE's Avatar
If its a turbo you got two small hoses for coolant.one on top is easy ...lower one is a royal asspain to replace. Only use volvo brand on those ones.
rudva
Jun 27, 2019 02:46 PM
audraseth10
Feb 3, 2019 11:34 AM
bhoodjalator
Nov 12, 2017 08:56 AM
jefflamonica
Dec 10, 2016 07:11 AM
CaseyB
Nov 27, 2012 06:13 AM
