Coolant Leak in the cabin?
Old Jun 25, 2019 | 02:35 PM
rudva's Avatar
Unhappy Coolant Leak in the cabin?
Weeks ago I change almost the whole cooling system (radiator, upper hose, thermostat, thermo switch, housing, expansion tank and cap) and has been working perfectly but today I check the levels, the coolant was low and the driver carpet is wet.
How is that?
Any ideas where can this leak comes? where to seek for the hose leaking or something else...?
Old Jun 25, 2019 | 05:55 PM
ES6T's Avatar
Sounds like a leaking heater core.
Old Jun 27, 2019 | 02:46 PM
its also possible the work moved the hoses that go from the block to the heater core that disrupted the o-rings that seal the hoses into the heater core. either way you'd need to open the console sides to inspect. Replacement heater cores are not that expensive so you may want to consider doing the hoses, new o rings and new heater core and be back to like new condition.
dejr
Jan 24, 2022 10:48 PM
RedSweed
Jun 6, 2019 07:42 PM
bhoodjalator
Nov 12, 2017 08:56 AM
CaseyB
Nov 27, 2012 06:13 AM
miximura
Apr 8, 2007 10:16 PM
