Coolant leak above transmission and wet floor?
Old Jul 30, 2012 | 09:31 AM
kkarasch's Avatar
Default Coolant leak above transmission and wet floor?
Ive been losing coolant for a while now. replaced the reservoir cap and it fixed a small leak there but i still was losing coolant. Yesterday I topped off and this morning it was all gone. Thought i found a spot above the transmission under the air intake duct but i haven't had time to pinpoint that. Is there a common spot under there where leaks occur?
Then when i got to work i noticed the drivers side carpet was soaked. I thought the heater core was more towards the passenger carpet.
Old Jul 30, 2012 | 09:44 AM
slimflex2's Avatar
the heater core is on the drivers side.removing the heater core has to do with working on the drivers side not the passengers side. you probably answered your own question.the heater core is probably gone.warm up your car and turn on your heat, get back to us and tell us if you smelled something with the heat on.
do you see any coolant on above the transmission? pictures will be appreciated.
Old Jul 30, 2012 | 09:48 AM
kkarasch's Avatar
yea. almost positive it is.i'll test it when i leave work. What about the leak above the tranny though? what hose is that? Still new to these cars.
Old Jul 30, 2012 | 10:37 AM
slimflex2's Avatar
it will be a good idea when you take pictures of the leak seen on the transmission.we can figure out which hose is leaking.
Old Jul 30, 2012 | 10:51 AM
slimflex2's Avatar
where are you located? if you are located in NY that will be good.l can help you out that way.
Old Jul 30, 2012 | 11:32 AM
His profile says SC. One of the few people that include that. LOL
The heater core is in the middle of the interior behind the radio. It usually leaks on the drivers side. Also, the tubes that run to the core are on the drivers side.
If you get enough water on the floor it will leak under the car and maybe on the tranny, kinda doubt it. The hoses to the heater core go through the firewall on the drivers side. If they are leaking, maybe it can spray coolant on the tranny.
FIX IT BEFORE YOU OVERHEAT THE CAR AND DESTROY THE MOTOR.
Old Jul 30, 2012 | 11:47 AM
slimflex2's Avatar
TRUE and well said.LOL. whats SC?whats the name for that state?LOL
Old Jul 30, 2012 | 12:47 PM
kkarasch's Avatar
Yea. I have never even let the temp get above the middle. I'm just glad its not the HG cause i got the car running great. Just have to shim the AC compressor next and i'll be set!!!
Old Jul 30, 2012 | 01:55 PM
On the AC, I used the zip tie method but would do the washer method next time.
Old Jul 30, 2012 | 01:56 PM
@ Slim: Yes, Charleston South Carolina.
Old Jul 30, 2012 | 11:07 PM
slimflex2's Avatar
why yall in the south?LOL..
Old Jul 31, 2012 | 07:11 AM
Yea, in the South but I grew up in the Pittsburgh PA area. I don't tell everyone that, wouldn't want them to think less of me. Lol
Old Jul 31, 2012 | 09:07 AM
kkarasch's Avatar
Here is the spot where it looked like it was leaking below the intake air duct. hard to get a good pic.
100_1543 | Flickr - Photo Sharing!
Old Jul 31, 2012 | 09:27 AM
kkarasch's Avatar
Is the URO 9144221 a good replacement? I don't know anything about this brand.
More Information for ÜRO PARTS 9144221
Old Jul 31, 2012 | 10:23 AM
slimflex2's Avatar
how much was it if l may ask? l would recommend OEM if you can afford it and also plan to own the car for a long time.
Old Jul 31, 2012 | 11:47 AM
kkarasch's Avatar
with shipping like $58
Old Jul 31, 2012 | 12:16 PM
  #17
slimflex2's Avatar
thats pretty cheap. l have never used that part before, so l dont know how good it was made. but if you plan to own that car for a long time go with OEM behr heater core if your pockets allows it.they last longer.fcp has one for cheap like 112 plus a discount with free shipping.
Old Jul 31, 2012 | 12:18 PM
  #18
slimflex2's Avatar
its sad,because it seems like l am the only one up here and yall waving up at me.LOL.
Old Aug 1, 2012 | 09:28 AM
  #19
kkarasch's Avatar
what about the nissen brand? anyone ever use that one?
Old Aug 1, 2012 | 10:15 AM
  #20
OEM, Bher, Nissen, all 3 are good and I have used them.
