Cracked Coil, Fryed Starter and no Crank
2 Attachment(s)
After installing new engine and trans.
fixing at school i got it running once. towed it home after that the problems started tryed to start it agian and would not turn over I hear all the relays clicking but no crank then after a couple more trys i hear a pop and to my surprise i find this Attachment 22737 after that i pulled the starter and found out it was fryed so went searching and found anohter coil and starter when i installed used coil and starter after trying to start i hear another pop and find this Attachment 22738 |
There is something wrong in the wiring you need to double check everything.
Fixed
2 Attachment(s)
Did alot of searching and found a Wiring Service Manual.
Link to web site: http://mojevolvo.pl/wiki/Strona_g%C5%82%C3%B3wna not in English but it easy to figure out all in PDF. and found out i had a Ground in the wrong spot Number 31/4 was connected to the Frame not the engine. Attachment 22721 Attachment 22722 |
Glad you got it now!!!
