Cracked Coil, Fryed Starter and no Crank
Old May 22, 2009 | 03:18 PM
Johnathan7878's Avatar
Exclamation Cracked Coil, Fryed Starter and no Crank
After installing new engine and trans.
fixing at school i got it running once.
towed it home after that the problems started
tryed to start it agian and would not turn over
I hear all the relays clicking but no crank
then after a couple more trys i hear a pop
and to my surprise i find this
after that i pulled the starter and found out it was fryed
so went searching and found anohter coil and starter
when i installed used coil and starter
after trying to start i hear another pop
and find this
Old May 22, 2009 | 09:32 PM
There is something wrong in the wiring you need to double check everything.
Old May 24, 2009 | 11:10 PM
Thumbs up Fixed
Did alot of searching and found a Wiring Service Manual.
Link to web site:
http://mojevolvo.pl/wiki/Strona_g%C5%82%C3%B3wna
not in English but it easy to figure out all in PDF.
and found out i had a Ground in the wrong spot
Number 31/4 was connected to the Frame not the engine.
Old May 24, 2009 | 11:15 PM
Glad you got it now!!!
Fradog
Feb 1, 2014 06:05 PM
baustin
Nov 11, 2007 12:15 PM
v70pain
May 16, 2006 02:55 PM
