cruise control
#21
If you have a hand pump then remove the hose that runs to the car and pull vacuum from there and watch the throttle cable and wheel to see if it moves. Also if you have a wiring diagram check the connections and you could also hot wire the pump and watch from there.
If that is all good then it will be come more complicated.
#22
#24
#26
#27
I checked under the dash and everything there looks fine. I did notice that the switch at the brake pedal has an adjustment that clicks as you adjust it. It can be adjusted closer to the brake pedal so it pushes all the way in when the brake is released.
I guess I have to pull the battery and check under the tray. Who thought that was a good place for the cruise vacumme pump?
#28
#29
Well, I finally fixed it. I looked as best I could without removing the battery but could not see any holes or breaks. I had a few holes, very large ones. Again, who's idea was it to put the cruise control unit under there?
I pulled the battery and the tray and found that both of my lines had large holes in them, hard plastic tubing. The cruise control line and the turbo boost guage line. I cut them and put a rubber vacuum line to re-connect them and now both works great. :-)
#31
Did u take a look at these instructions?
https://volvoforums.com/forum/volvo-850-16/cruise-control-not-working-turbo-boost-guage-not-working-29883/
