cruise control
Old Feb 14, 2010 | 07:07 PM
radio16's Avatar
Default cruise control
any one have diagram for cruise control vacuum lines please - i need them - just recieved cruise control module for under battery mount but no vacuum on line need to find where it comes from and where it goes - CHILTON MANUAL AINT WORTH THE TOILET PAPER IT WAS PRINTED ON!!! THERE IS NOTHING FOR TURBO MODELS IN IT EXCEPT FOR A 1/4 PAGE -- BUT ITS OK I GOT ALL YOU WONDERFUL PEOPLE THAT HAVE KEPT ME HIGH SPIRITED AND ON TRACK WITH EVERYTHING --- THANKS TO ALL
Old Feb 14, 2010 | 07:13 PM
There should be a black plastic hose under the battery tray with an elbow on it.
That would be the hose you need.
Old Feb 14, 2010 | 08:02 PM
mhutchens's Avatar
There isn't really a vacuum diagram for the cruise control because it consists of one hose that attaches to a bellows above the accelerator pedal to the cruise vacuum pump. The vacuum hose goes through the firewall in a wiring loom that is close to the brake master cylinder.
Old Feb 14, 2010 | 09:17 PM
radio16's Avatar
cool thanks -- my car is now totally oil drip free thanks for the idea on that too
i would love to pick a good name for my car and Pearl and Kristine are just not suitable for her!
can you think of a good name ?
dude wait till you hear this bad girl she is sooooo quiet - like a panther waiting to strike- coz i know whats under the hood and i am pretty sure you do too- my next trick will be to set the boost correctly - i messed it up when i stripped down the turbocharger and rebuilt it - but it is perfectly balanced- so how many pounds vacuum do i need to set the turbo accurately in order to set up the wastegate ?
i was told 4 lb 6 lb 9 lb 10 lb 14 lb - which one is correct ?
Old Feb 14, 2010 | 09:35 PM
I will try to find it and post it. I know I have posted it before. I know it is was in the one 850 post about a guy having running problems after an ECU tune.
Old Feb 14, 2010 | 09:40 PM
Page 4 of this post has the way you need to do it with all the model numbers and PSI to set it to.
https://volvoforums.com/forum/showth...problem&page=4
russ
Mar 8, 2017 10:10 PM
rspi
Mar 7, 2010 06:13 PM
jfikentscher
May 31, 2006 09:58 PM
Talon
Jun 1, 2005 01:04 AM
CFGVolvo850
May 24, 2005 12:38 AM
