cruise control
Old Mar 24, 2006 | 07:36 PM
maron96's Avatar
Default cruise control
My car is 1996 Volvo 850. I was reading the post about cruise control problems. I read about the connections under the battery, I noticed on my car, under the battery there is small black tubing, I can say "tubing" because the is no cable inside, it was cut not sure if it was accidentally cut or they did it in purpose. My car just came from dealership to have PNP switch and center console switch replaced, after they have it replaced the cruise control did not work at all. Facing the car the tubing is connected infront area under battery, there is a running blue cable close to it, it looks like a ground. Anyone know if it is related to cruise control? I'll try if I can post the picture.
[IMG]local://upfiles/3977/0CE140B8E45D4FE7B4BFE7213389BF5D.jpg[/IMG]
Old Mar 24, 2006 | 09:44 PM
Default RE: cruise control
It is hard to see good the Picture is to small. But I think that is the hose for the cruise. It should lead to under the battey tray. The motor is mounted to the bottom of the battery tray.
Old Mar 24, 2006 | 11:22 PM
maron96's Avatar
The one with circle mark.
[IMG]local://upfiles/3977/FC723EBC0C5A4DE8AB9439AB9FF92D84.jpg[/IMG]
Old Mar 24, 2006 | 11:57 PM
ORIGINAL: maron96
Can you make the picture a little bigger?
Or E-mail it to me in fullsize. Then I will edit it and repost it.
Old Mar 30, 2006 | 03:14 PM
maron96's Avatar
Tech, I'm glad you recieved the pictures that I email you...Thanks for the instruction how to fix it, my cruise control is now working.
Old Mar 31, 2006 | 09:58 PM
Congrats!!
russ
Mar 8, 2017 10:10 PM
rspi
Mar 7, 2010 06:13 PM
jfikentscher
May 31, 2006 09:58 PM
Talon
Jun 1, 2005 01:04 AM
CFGVolvo850
May 24, 2005 12:38 AM
