Cruise wont work?
I have fixed all the other problems on my daughters 1997 850 T5, the odometer fix with the new gear was awesome. All the "lights" on the dash are now off, except for the "light" for a burned out/not working third brake light. I replaced the buld but it still doesnt work, I was told that, that is the second switch on the brake pedal and also connected to the cruise conrol, and if it is out of adjustment or unhooked the cruise wont work. is this true? any other things I should look at to see whats wrong? Thanks for your help!
The third brake light is powered off the same brake light switch as the rest of the brake lights. The second switch is just for the cruise. I would guess you have two seperate issues.
For the brake light, trace the wiring from the back window and check for breakages etc, maybe test the socket with a multi meter while someone presses the brake pedal. For the cruise, check the second brake pedal switch, vacuum hoses and vacuum pump (under battery tray) |
Originally Posted by theboneskes
(Post 322765)
