Current Volvo Codes
Old Jun 15, 2008 | 11:35 PM
Quick Brick's Avatar
Default Current Volvo Codes
Hey now,
I have gone through and cleared the the codes and even got the lambda/check engine light but these have come back.
A3 – ABS
141 Faulty pedal sensor, shorted to ground or supply
142 Faulty brake pedal switch, open or short
Could this be related to one or both of the switchs at the top of the brake pedal?
A6 – Ignition
131 Engine speed (RPM) sensor signal missing
214 Engine speed (RPM) sensor signal missing sporadically
241 EGR system flow too low in system
314 Camshaft Position sensor (CMP) signal missing or faulty
324 Camshaft Position sensor (CMP) signal missing sporadically
Can this be caused by a faulty cam position sensor? 241 - Exhaust Gas Return..........going to have to lookin the manual about this one.
A7 – Combined Instrument (Trip Computer)
122 Temp. sensor interval too long
132 No RPM sensor signal
B1 Electronic climate control
411 Blower fan seized or drawing excessive current
413 No control voltage at drivers side interior temperature sensor inlet fan
414 Drivers side interior temperature sensor inlet fan seized
Is this located behind the littleholebehind the handleabove the drivers door?
415 Passengers side interior temperature sensor inlet fan shorted to earth
416 No control voltage at passengers side interior temperature sensor inlet fan
417 Passengers side interior temperature inlet fan seized
418 No control signal to blower fan power stage
Not sure what the rest are pointing to so suggestions are welcome.
I am posting a pic and need to kow what you see and what might be causing it. This is the second time it has happened. First time wasI town and this time on the highway.
What do you think?
[IMG]local://upfiles/14053/D7E7EEAEA564448082E34FD4C6C566AB.jpg[/IMG]
[sm=icon_cheers.gif]
JBVolvo
Aug 1, 2013 02:55 PM
newguy05
Apr 23, 2010 02:22 AM
BriGuy
Mar 10, 2008 12:49 PM
97GLT
Sep 7, 2007 07:23 AM
ohmab
Apr 23, 2004 12:29 AM
